Belkin n300 wireless modem router - Connect to wireless network
Veroland
South Crest, Alberton
I know this is a long shot, but I have the Belkin N300 adsl router and I was wondering if it is possible to have this router connect to another wifi network.
I want to get one of those MiFi routers from Afrihost since my adsl is extremely unstable and would like the router to connect to the MiFi hotspot and being able to then allow internet access on the wired pc's.
I am also thinking of getting another wifi router at some point and connecting the 2 so I can better coverage at home.
Hi There,
Just need a bit of clarity. Are you trying to connect the Belkin through Wifi to the mifi or do you want a cable to connect them?
A diagram might help
Regards
Tim
So are you going to replaced your current ADSL with the mifi from afrihost?
And you now want to use the current router as a WiFi extender?
I am not sure of the capabilities of the mifi device on offer from Afrihost but their man on this site should be able to assist.
I did have a brief look at it and if you can get into it to set it up in bridge mode then you should be fine.
Regards
Tim
