best lcd screen for a ps3?
MaddyJ
Pretoria
hi guys. . . im planning on getting a lcd monitor for my ps3, about 24"... it needs to be full hd aswell. any recommendations on the best possible one?
thanks!
Bravia :) I think u get the small ones (mayb 27 is there smallest)
that is pretty pricey though? what about the samsung ranges? like the 2333SW?
I have a 2333SW at work, really nice monitor(full hd, 20000:1 contrast, 5ms)... but there's some new Samsungs out now...
check the p2370 which is 50000:1 and 2ms, or the Samsung 2494 23.6" with 50000:1 and 5ms, with an HDMI input...
my budget will be around 3k. . . any advantage of the led display compared to lcd? and is it worth it?
Also take a look at the Sammy P2450.24" Full HD, 70 000:1 contrast, HDMI,dvi,vga. Picked mine up for R2100 with free delivery from webantics last week :)
Definitely go Samsung if you going LCD...the 2333SW is great, but no built in speakers and you need a HDMI/DVI converter.
The 24" series like the 2494 and 2450 are great too...they come standard with HDMI and some models with built in speakers...
Guy, for such a small screen, full hd wont make a difference from HD ready.
U usually need >40" to see a difference.
so i found a screen i like. its the samsung p2450h... anyone own this monitor? im battling to find reviews for this screen... the specs are good and has a nice price! any views on this product will be greatly appreciated...
