hi im very new to ocing what liquid cooling system would u
recommend for R2000 i would like to oc my i7 920
You know that you can get 4GHz on air?
if you're cool with your cpu running at 75c (thereabouts) then air cooling would work![]()
go for a Swiftech kit or build your own loop with danger den, swiftech etc. parts
Whatever you do DO NOT GET THE SYSTEMS MADE BY THERMALTAKE, COOLERMASTER, ZALMAN etc., go for a Swiftech kit or build your own loop with danger den, swiftech etc. parts
For R2k what's he going to import from Swiftech and Dangerden?
