Samsung PRO Endurance, Class 10Hi Guys
Which are the best microSD cards for the Raspberry PI 4 model B ?
thanks
Kitty
My Sandisk sdcard is still chugging along great a year later. Use my pi daily as well since it's my main PC.Samsung PRO Endurance, Class 10
the issue is, SD cards are not a great medium for storage (many reads and writes) to begin with. So buy the best SD card you can afford (relative to how much the impact of it breaking is worth)
I still believe the PI should have a nand flash onboard
but anyway,
SD cards, I burned through my Scandisks a lot
Went with the Samsung one and been fine so far, couple bad sectors but not dead yet ie already lasted twice as long as the Scandisk did at this point.
I now use, Samsung Evo and Samsung Enduro SD cards only
Also in my Arduino / ESP32 loggers
An SSD drive ?Hi Guys
thanks
Kitty
This is exactly my use case as well.I recently moved to an external 2.5" HDD. the Sd card was slow to update software, and just generally pssd me off.
responsiveness is miles better now.
I use mine for pihole and unifi server.
So, I'd say just go with an SSD or normal HDD.
Would be keen to know how you are using your Pis.Depends on how the Raspberry Pi is going to be used. We use either Sandisk or Samsung Micro SD cards in our Raspberry Pi's which run 24/7/365 and they write constantly to the cards. They're cheap enough that we can replace them when needed. Due to the nature of the Micro SD cards, we do have to replace faulty cards occasionally. We have over 300 Raspberry Pi's in the field.
If you really want a good quality Micro SD card you would probably have to look at Micro SD cards that's designed for video monitoring as these are high endurance cards and can be pricey.
We have clients that run various types of testing equipment and instrumentation. the Raspberry Pi sits between the testing equipment and the network. The Pi constantly gathers the data from the equipment and sends them to the various servers or locations.Would be keen to know how you are using your Pis.
