Best plishing machine out there?
ALFAHOLIC
Best polishing machine out there?
Hi, I want to buy myself a poishing machine or a polisher or whatever you call it. I normally take my car to a place here in town and it glazes the car...I don't know what machine they use but its brilliant - make faded red bumpers look like new...
I see machine's that cost R500, R700 and up to McGuiers R1500 machines...I'm not one for names etc, but what's a good one, but at the same time not expensive?
Cheers:cool:
That's probably because it takes a thin layer of paint off so every time you use it the paint gets thinner and thinner. Just something to keep in mind, not something I would do on a regular basis.
Sheesh. I thought you where asking for a phishing machine.... :eek:
Valet centres and panel shops would mostly use high speed rotary polishing machines. They offer excellent correction ability, allowing the user to remove deeper scratches on paint. Furthermore, they are effecient compared to other polishing machines in that they remove defects a lot quicker.
There is downside to rotary polishing. A rotary polisher in the hands of a novice user could result in paint burn through (when you create so much heat that you compromise the clear coat and burn through it) and some users leave horrid holgrams on paint which impare the general look of your car.
Lets start here, what are you trying to achieve? If you are concerned about faded paint and trim, then you can use hand applied products which will remove the oxidation and bring life and vibrancy back to your car paint. If you want to remove swirl marks (cobwebb effect on paint) and minor scratches (if you run your finger nail against the scratch and it catches, then you wont be able to remove the scratch with a polisher alone) then I would recommend a dual action ("DA") polisher.
Unlike a rotary polisher which rotates in one direction, a DA machine oscilates. This action is great for enthusiasts that have not been trained on machine polishing. They are fool proof, the chances of burning through paint or creating holograms are limited. There are a few DA polishers in the market however, the Meguiar's G220 polisher is the most widely used. I believe Meguiar's and its distributors are selling this machine at a discount at the moment, down from R3,000 to R2,100 at one of the online stores.
Becarefull of cheaper machines retailing at less than R1,000. These are mostly orbital machines which don't have sufficient power to remove paint defects.
To start off, try to achieve the desired results by hand. Failing that, you can look at buying a polishing machine. Remember to apply a coat of wax when you are done. This will prolong your results and delay the fading your experienced.
Thanks dude...I actually just want to give the car a polish now and then without braking a sweat...I guess that's not only naive but also lazy...I'll try the hand thing, as I always did, and see how my muscles grow from constant circling!
You can achieve a lot with the right technique and product. Try to find a bottle of Autoglym Super Resin Polish ("SRP"), a foam or microfiber applicator pad and finally a microfiber cloth to remove the product a buff to a shine.
