I have a SYNAPSE 3000VA/2400W (V+) 24V Off-GRID Inverter (https://www.takealot.com/synapse-3000va-2400w-v-24v-off-grid-inverter/PLID69233408) and I'm looking at getting solar pannels.
Attached are the MPPT specs. It can support 1000w charging, but the operating solar voltage is 80v, with the max 102v.
If I look at any solar panel over 400w, the voltage is more than 40v, which means two panels in series will be over 80v.
My question is what solar panel size would be the best combination and does anyone know where I can get stock?
Thanks!
Thanks!
