Best way to fix this?
rh1
Somewhere close to you
So I bought a wooden blind to replace the old aluminium blind that was broken. I decided to install on the inner opening of the window to match other blinds already installed by the precious owners.
Whilst creating a marking hole with a punch, the corner cracked and eventually broke off, see pics:
To add, I do have matching paint.
Do I use pollyfilla or is there another solution?
Smith&co have a small bag of ready mix plaster, ideal for fixing things like this.. it's not a structural repair, so you shouldn't drill into it afterwards.. before repairing drill hole for your plug and use a longer plug, one that will expand in the wall beyond the section you will repair..
Trip to specsavers and then some polyfilla
  • Haha
Reactions: rh1
If you wanted the repair to be as strong as the plaster you could use Rockset or something similar.
You shouldn't be drilling that close to the edge. I would just use the two right side holes and upsize the fisher plugs a bit.
To fix it any filler should be fine.
  • Like
Reactions: rh1
I was trying to match the look of the previous installs which was flush. I will recess it further.
