Best wide angle IP camera?
ivanlotter
Rural
What is the best wide angle IP camera? Wireless that will connect to wifi.
I use these. Go to the gadinan store and check out the WiFi versions. I have a WiFi one for the newborn and it works fine, rest are on wired.
Great cameras, 4 years so far and cheap as chips.
Is it wireless?
What do you mean by 'wide angle' (by which I mean horizontal field of view)? Also seeing as a camera HAS to have power anyway, why a wireless camera when you can just run power over a network cable and have, frankly, better video feed anyway? And if, because reasons, you are just unable to run network cable, how about expanding on what situation you do have there so you can hopefully get better grade input?
