Better pings with RAS PPPoE client - help :(
Nemesis
South Africa.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
Yip, if 10ms makes a huge difference in your life, head on over to http://www.raspppoe.com
The results:
Pinging mayhem.co.za [196.35.64.184] with 32 bytes of data:
Reply from 196.35.64.184: bytes=32 time=10ms TTL=59
Reply from 196.35.64.184: bytes=32 time=11ms TTL=59
Reply from 196.35.64.184: bytes=32 time=12ms TTL=59
Ping statistics for 196.35.64.184:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 12ms, Average = 11ms
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
That post was from Timmee in the old section of the forums, I tried what he said, downloaded that program and now it gives this problem, what am I supposed to do to fix it? I realise installing that is quite easy, but I dunno how, plz help...
http://www.planetmarsteam.com/matoko/uploads/view.php?pic=adslprob.jpg
That'll teach you! [}:)] Never install/load/run anything on your machine unless you know how to recover to where you were before - a basic principle from the 'old' school of computing before the advent of PC's... Anyway, looks like you've lost your network device and layers. Based on your .jpg, you're probably running Windows - try doing an 'Add New Hardware' in the Control Panel first, then verify the device is there under 'System'. If so, then reinstall the network layers also via 'Network Connections' in the Control Panel... GL!
