BF4 Crashing | Please help
Andrew_Smith
Hi guys,
So I am getting a new error or crash from Battlefield 4. I can play 1 - 2 games fine, but then my game randomly crashes.
It say "Transitioning"
Any advice? I will really appreciate your guys help!
Note: I have a 64 bit operation system Windows 8.1 Pro, and I think my game is running in 32bit. Could that be a problem? Also my Origin is also 32bit.
Thanks.
EDIT: My game freezes, so I need to close it via Task Manager
Hi guys,
Thanks.
You use sweetfx?
Okay cool, I check that! Mine is running in 64bit... But, when I right-clicked on BF4, a option "Repair My Game" was on the list. I am currently running that.
EDIT: Repair My Game is verifying my game files.
Hi guys,
Thanks.
-How new is this build?
-Anything major changed?
Brand spanking new! My build is turning 1 month old 19 July. It's weird? Because this is a new error I am getting and it is really frustrating! It makes me not wanting to play Battlefield.
Note: I had this error/crash at the start of my new build, but that was just once in a blue moon.
Now, it is more frequently.
Okay, I still got the same problem by doing the following:
1.) Repairing the game via Origin
2.) Using another browser (aka IE)
3.) I disabled Origin in-game
4.) I updated my GPU Driver to the latest
Any suggestions is more than welcome!
Ok, this is what I would do.
-Download snappy driver installer and copy it to a USB
-Download GPU driver and copy to USB
-Update mobo BIOS
-Format and reinstall Win 8.1
-Fully update the OS then restart
-Install GPU driver
-Run snappy driver installer
<Restart ETC>
-Install VC Redist x64
-Install Direct X from microsoft (DX web installer)
-Install BF4 from scratch.
Okay, I may have solved my problem... I downloaded the latest BIOS version and so far it worked! I played two matches straight!
Will confirm this in the morning though.
:D
EDIT: Thanks for the advice Rickster, but if this fails, I'll try your suggestions by waiting for Windows 10.
I confirm that the BIOS update fixed my game!
Thanks for all of your support guys!
