Canonized Villain
- Mar 9, 2010
I lurked a bit but didn't see anything related to my problem.
I'm having trouble with forwarding ports for Azureus/Vuze.
I've followed instructions on portforward.com, though the closest match to the Billion 400g I could find was the BiPAC 7300(G) RA.
The instructions were pretty simple and easy to follow :
Them Apples
After I 'opened' the ports, 6881 and 52***. I went back to azureus and did a NAT test. The test came back negative and informed me of the following :
NAT Error - Connection to 198.54.202.166:52*** (your computer) refused
Proxy IP is '41.246.146.116', original is '198.54.202.166 ('Forwarded-For' request header was '198.54.202.166, 198.54.202.195').
I shut off all my firewalls both on the router and windows to see if it would make a difference but sadly it didn't.
I used portforward.com's port checker just in case i was getting false positives, the port checker also came back negative.
I'm connecting to my router via WiFi.
Please help
Them Apples
Please help
