Billion 800VGT - need two WAN links
DarrylH
hi guys,
I have a Billion 800VGT, connected via VPN Lite to my home router.
the two routers can see each other fine, and the PC's as well.
I need to be able to allow traffic from the Billion router at work into my work network. How is it possible to do this?
i've added an IP Alias, set the static routes but my network is dropping the packets. So i need to use NAT, but there is nothing on google about setting up NAT on these routers for the application and situation that i require.
Work IP BILLION Router @ work Home Billion
167.229.215.x 10.0.4.2 10.0.5.2
Work can see Home and vice versa. IP Alias on work Billion of 167.229.215.190
static route send everything for the VPN IP's via the VPN WAN Link, and everything else to 167.229.215.190. How do i setup NAT so that my packets leaving the Billion router at work leaves via the 167.229.215.190 WAN IP with a 167 IP range address?
I have a Billion router from IS via Brandedinternet and use a D-Link DIR-130 VPN router between the Billion and my network – so the DIR-130 is my gateway or xxx.xxx.xxx.1 – it have 8 LAN 10/100 and one WAN port that I use the WAN to the Billion and then one LAN to connect to my 24 port home gigabit switch…
Hope this can help a bit.
http://www.dlink.com/products/?pid=563
so basically, it's using two device as "one" and then allowing you to see work servers and network from the home PC?
any special routing to be done?
I have a ASUS 500G that i can use instead of your DIR-130. Will try tomorrow.
