Billion firmware for Mega200VWR ???
///MoH
Durbz
Ok iv searched and haven't come to a solid conclusion...
Which model billion firmware works on the Mega200vwr ?
7404VGP or the 7401VGP
MoH
My 7300M reports:
Hardware Version TRENDCHIP TC3162
Software Version 1.35-RC7-180-80.3_sso_billionsa
Bootrom Version 1.06
You might want to use the details in your search. (by comparing those routers of course)
Hardware Version Argon 432 ADSL-A/WG/VOS v1.00
Did a quick google search of the hardware version...The only router to be mentioned is the 7404vgp
Im guessing the 7404 firmware will work then
I wouldn't want to test it, might brick the router, but if you're game and it works, report back :p
Firmware Upgrade
Firmware Upload Failed
Wrong firmware type.
The firmware is not match to your current hardware type.
Please double check your model name and ADSL Annex type on status page.
So much for that....
Tried the BiPAC 7404VGP AnnexA firmware.
I remember feo mentioned something about another firmware type he was using on his Telkom Mega router. I'll try to search for it.
Ok cool..Thanks for your help man.
Time for me to hit the covers....Will check up in the morning
Cheers.
