Hey there.
Activated a few days ago, BIS (Blackberry Internet Service), for my HTC P3470 handset.
I have already done my part of the homework beforehand, contacting both HTC and RIM directly to confirm that (paraphrased from RIM) "any Windows Mobile capable device can install and use our Blackberry Connect software".
Downloaded and installed as per RIM and HTC's advisement, the latest version of Blackberry Connect (4.0.0.106).
Software installs fine.
After install, phone prompts to reboot and does so just fine.
But Blackberry Connect only connects for 2 or 3 seconds, then disconnects itself again. No errors. Just disconnects.
In the Blackberry Status page... "PIN: Pending".
I have tried every other solution available online to no avail. I checked and double checked again, with RIM that ANY WINDOWS MOBILE DEVICE CAN USE BLACKBERRY CONNECT SOFTWARE. (http://www.blackberry.com/btsc/micr...UE_1_1&dialogID=52247724&stateId=0 0 52249441) --- make life easy for everyone, they even were kind enough to email the links to that same answer they gave me.
They told me that if any such problems of PIN
ENDING occur, it is due to the network provider not properly provisioning that SIM for service. (see above link)
Please, what do you need of me to get this working?
I have more than my fair share of the research and troubleshooting in this matter only to achieve nothing. I have notified MTN call centre via 808, only to get "You will need to take this matter up with your handset manufacturer for compatibility issues"... now boys@callcentre... dont MAKE me say bad words.
