Please note that MTN is currently experiencing network problems with blackberry link to Rim network.
Unfortunately we do not have a turnaround time, you will have your services back as soon as the problem is resolved.
Apologies for any inconvenience caused, should you have any problems don't hesitate to contact us on 1555.
Thank you for contacting MTN Blackberry Support,
Remember weekends aren't the problem, it's weekdays.
That said the BIS 2.8 upgrade was supposed to go through on European servers last night so maybe it's permanent?
EDIT: Bear in mind the speed test is giving you results in bit and not bytes so Piesang divide your speed by 8 to get kbps. I thought 189kb was too much for Edge.
