blackmagic deckline extreme
spot-ed
Hey all!
it seems i just have one problem after the other!!
i've got a decklink extreme pci card installed in my mac pro. hooked up a betasp machine to the decklink but the computer's not talking to the sp machine at all. i'm trying to capture video into the fcp but it's saying that there's no video device connected. not sure what i'm doing wrong. is there any specific setting that i'm supposed to be using.
help!!
Sorry, capture via Firewire only and analog stuff I capture on a PC with the Matrox Extreme RT Pro. I suggest you try the apple.com forums under Final Cut Pro, you should also try DVInfo.net forums.
