Blinker Fluid
Genisys
There
I just ran out of blinker Fluid, anyone know where I can get some? Everyone shop I phone doesn't have stock of blinker Fluid. How are we suppose to top this up if there is no stock?
I had that problem once too. I eventually found some next to the sparkplug grease. Midas has it.
I had to get mine off of the dark web, quite difficult to get a hold of and its not cheap.
While you are adding blinker fluid you may as well check that the muffler bearing is still present and fully functional. If not, replace as well
YOu can make your own. It's waaay cheaper than the stores!
Take Nitrogen based fertilizer (about 200g's) , add about 500ml unleaded petrol, then some hydrogen peroxide or pool acid (about 200ml) mix it all then let rest for about an hour.
Add that to the blinker and BOOM! it'll work like a bomb!
Next to the left handed screwdrivers and long weights.
