Block certain phone calls
If you are using an Android/iOS phones you can download a call blocker, there's plenty
Call blocker (freeware) also available for most Nokia models, post what 'phone you have and the guys will help you
Try the Mr Number app for your BB - It should be on AppWorld. It can send blocked numbers to voicemail. It can also block SMS and allows exceptions to blocked numbers.
If you are on cellc, logon the mytools on their website. You can do it from there
