blocking p2p over a wireless connection
Rambo69er
hey guys
is there any way to block p2p over only a wireless connection?
therefore if you use a cable you will have p2p access adn over wireless u wont
im using a netgear wireless adsl router
What model of the netgear do you have, and i doubt that any of the Netgears for home use have that option.
Netgears cant do lower level shaping. You can just block ports i think but thats about it.
