FrozenToast
- Jan 12, 2023
Hi everyone
I ordered two 13v 108ah Blue Nova lithium batteries to run in series, the ones without the BMS connection to inverter. But with built in BMS for the battery,
Of course I now need to manually set the charge, float and low battery voltage. Can you kindly advise me what those voltages should be as the interwebs seem to differ by about 1 to 2 volts on all the pages I read.
Thank you
Thank you
