My central locking on is not working the unlock button does not open any of the doors - when i open with the integrated key only the driver's opens, the switch on the inside doesn't work....the trunk seems to open, but thats about it...any ideas
Disconnect the car batery, wait 10 minutes and re-connect it. Then the alarm system will reset. It worked when my Jetta's central locking gave issues a while back.
must be the battery in the key, or maybe the key is just broken. is it the e46 or the e90 model ?
Blown fuse?
Check the batteries in the key and in the car.
If its not the battery, then sell the car and buy a Merc or a Bentley, much more reliable.
Since it's an E90 it's probably still covered by the motorplan, I'm sure your dealer would be able to sort you out.
If not it might be time to get out the vaseline.
