Bold 9700 replacement battery
I ordered off Ebay and 4 new batteries cost me in the region of R600.00 in total.
Hey marine. Have u booked the phone in at vodacare for a check? I normally recommend this to clients to make sure it is in fact the battery and not the charger. U don't wanna go spend that dosh on a battery and then the fault lies somewhere else. Does it not charge at all. Or does it not hold its charge?
Where are u based?
I got a 9300 and the battery life was utterly pathetic. I put the 3G off and it lasts much longer
Where are u based?
Hi there, thanks man, we put in another battery and it works perfectly.
The battery does not charge at all. Problem is, the phone was bought on Bidorbuy and comes from the US but the phone is fine, its the battery
