Boost Rain Signal
Dubes
Hi,
I thought I'd give Rain a test drive. I am outside their shown coverage area but I am on a hill so I've found with Cell C that even though I'm shown as not covered I am (and get good speeds).
Unfortunately this is not the case with Rain (looking to use it in my B315). It battles to find a server with speed tests and then I get 5Mbps, if lucky, and non-existent uploads....
My question is whether a booster aerial is likely to help or would it be a waste of money. Attached are images of the Rain coverage, my distance from the covered area as well as an elevation profile map. Unfortunately there is a "hump" preventing "line of sight". The elevation is exaggerated due to the scale.
Worth pursuing or just pay more for extra Cell C data?
Hi,
I'm pretty sure if you point this in the direction of your nearest rain tower you should get decent signal.
https://www.geewiz.co.za/wireless-n...or-cpe.html?search_query=mikrotik&results=118
Get a Poynting XPOL-6-10. Perfect for a B315. But buy second hand, there are always a few on the market.
I was outside their coverage area too but I applied and it's working like a space shuttle to the moon.
Hi,
You're too far to get any good upload. Download can still be possible but will be spotty. Post your connection stats (RSSI, RSRP, RSRQ, SINR), then can give a more informed opinion.
