ivanlotter
Good afternoon,
I purchased a “Plug and Play” borehole kit (pump, motor, cable, and control box) with 220v three point plug however the earth wire supplied with a lug does not fit onto any of the bolts/studs on the motor housing. Can I just pinch it between then pump and motor housing, although then the two casings are not flush.
Any advice would be appreciated.
Ivan
Ivan
