Brake Caliper paints
Drifter
Vereeniging
Anybody have a clue where I can get. (Red). The usual suspects like Autostyle, MST dont have stock. JHB area.
I used engine enamel spray paint on mine came out brilliant and did not come off with the heat.
Should be available at many hardware stores.
How long ago did you do it though?
Just bear in mind that, if your car can't sprint to 100km/h in less than 7 seconds, having painted brake callipers will instantly identify you as a bit of a knob.
That makes near all Peugeot drivers knobs with their red Brembo calipers (those who have them). :p
Hey, manufacturers need to appeal to the knobby segment of the market too sometimes, you know. :D That said, not something I've noticed on poverty spec pugs?
If I remember correctly, OP has a Fiesta ST... That puts him 0.1 seconds within your criteria.
It's styling. How does that make one a knob? Huge spoilers and wide skirts I understand, but caliper colouring? Get off your high unicorn.
Mine aren't coloured but I see nothing wrong with it.
