Better to replace. Price for replacement vs skimming is not that huge. Most newer cars use ventilated brake discs at the front and if you skim those it might take off more than what the minimum thickness of the disc should be (not great for you if you get in an accident and your insurance uncovers this). Another point, always insist where ever you take your car and wheels need to come off that the wheel bolts are torqued to spec. Most over tighten and this causes the disc to bend which in turn causes brake juddering.I've always wondered if it was worth it to skim disks Vs replacing them.
NoIf you replace the disc itself, and fit new pads, do you have to do this skimming so the pads bed in properly?
You only change the disc or skim it when it is warped.Is it necessary? Won't it cause early wear and tear to the disc? Squeak while braking isnt so bad right?
