Hi,
I recently had all my discs replaced. After this, my brake lights are staying on. (Actual rear-lights not the brake warning light).
When I park, if I pump the brakes then the lights go off.
There is no travel in the brake pedal so dont think its the switch at the pedal. I checked the fluid and it is at the correct level, not too high.
Will be a mission to take the car back to the dealership that replaced the discs - so want to figure out how to fix myself if possible
Braking performance is great, there is no softness in the pedal either. Any ideas?
