Brake Pad recommendation
Aharon
Hi
What is your recommendation for brake pads for a hatch back (renault). Long lasting, with as little damage to the disks as possible.
I have heard good things about safeline
I have only had succsess with forodo preferably the platinum or ceramic. They are a bit harder on the disks but they work until the end ate tend to start getting brake fade half way through every time I tried them. Havent tried safeline, ebc is really good but not appropriate for the average hatchback.
