Brass Door Locks
KaMoS
Does anyone know someone who can repair or work on brass door handles and locks? My patio doors have brass handles and locks, and this one is broken. Currently using a plyers to open and close it, not ideal. Pics below:
1. Your garden looks massive, wtf? Do you you live in a country club?.
2. Looks like that this just takes a standard handle despite the odd mechanism (judging by the one to the right) is the mechanism itself broken? Have you opened it up? These things often ridiculously simple.
:oops:
Bliksem
And here I am living upstairs in a 2 bedroom apartment with not 1 blade of grass
Nor a door that has brass
Over 3 grand for one
Ouch
Cheaper to get an engineer here in paarden eiland to make something up for you
you can also buy brass spray paint at builders warehouse in a spray can
Cheaper fixing option and it's fun.
Make a silicone mould of one the working handles and buy some 2 part resin. Make a resin copy and spray-paint it to match the colour, you could embed that square/hex bar that actuates the handle inside the resin for strength.
Good luck.
Thanks for the responses all. Some good advice.
ALSO, thanks for the compliments on the garden, all thanks to my amazing gardener. If you're in or close to Bedfordview, he has days available.
