Bronberg Wisp and Mikrotik
saa044
Pretoria East
Ok so Bronberg Wisp installed my neighbors Antenna A while back. Everything was working quite well up untill a month ago, where the Internet would drop between 2pm and 3pm and be back after that, no biggy. But what bugs me is that about two weeks ago everything went belly up. They blamed the Antenna and came back with a cherry picker to replace the Antenna. The problem remained and then they blamed the Mikrotik router, replaced that and the same problem, little to no internet. As soon as I replace the Mikrotik router with a plain old R250 Tenda router and connect to the antenna via the Wan port and do a static IP to it we have flawless lekker internet. What can these guys be doing wrong on the Mikrotik to screw things up? I mean it is a standard DHCP server on the Mikrotik with a static route to the Antenna, not rocket science. The Mikrotik does not even dial to the Antenna.
