Building a WHERE clause in sql
Fuma
Pretoria
I have 3 text boxes (txtID, txtName, and txtSurname) in my webform and I populate a repeater based on the values in those text boxes. I need to build a WHERE condition and I want to avoid this:
Code:
dim WhereCondition as String = ""
if txtID.Text <> "" AND txtName.Text <> "" AND txtSurname.Text <> "" then
  WhereCondition = " id = '" & txtID.Text & "' AND name = '" & txtName.Text & "' AND surname = '" & txtSurname.Text & "'"
end if
if txtID.Text <> "" AND txtName.Text = "" AND txtSurname.Text = "" then
  WhereCondition = " id = '" & txtID.Text & "'"
end if
if txtID.Text = "" AND txtName.Text <> "" AND txtSurname.Text = "" then
  WhereCondition = " name = '" & txtName.Text & "'"
end if
sql = "SELECT * from table WHERE " & WhereCondition
Surely I can use a better combination of building the WhereCondition string.
I forgot the ElseIf part
So if I have 5 more text boxes, I have to redo the combination? No man
Code:
Dim WhereCondition as String = ""
Dim selectWord as String = "where"
if txtID.Text <> "" then
  WhereCondition = WhereCondition & selectWord & " id = '" &  txtID.Text &"'\n"
  selectWord = "and"
end if
if txtName.Text <> "" then
  WhereCondition = WhereCondition & selectWord & " name = '" &  txtName.Text &"'\n"
  selectWord = "and"
end if
if txtSurname.Text <> "" then
  WhereCondition = WhereCondition & selectWord & " surname = '" &  txtSurname.Text &"'\n"
  selectWord = "and"
end if
Dim sql as String = "SELECT * from table " & WhereCondition
Roo! has it, except for the bug. Can you spot the bug?
Well, there are two.
Yeah may end up with the sql string having WHERE in it more than once.
selectword begins set to WHERE. And you have a WHERE on the last line.
so, it will be WHERE WHERE
the second bug is if there are no fields set, then you will have "WHERE WHERE" with nothing after it.
Try this - VBscript is not my language of choice so you may need to tweak it slightly:
Code:
dim whereCondition as String = ""
  whereCondition = " id = '" & txtID.Text & "'
begin
  if whereCondition <> "" then
  begin
    whereCondition = whereCondition & " and"
  end
  whereCondition = whereCondition & " name = '" & txtName.Text & "'"
end
begin
  begin
  end
  whereCondition = whereCondition & " surname = '" & txtSurname.Text & "'"
end
  whereCondition = " where" & whereCondition
sql = "SELECT * from table" & whereCondition
Be advised that this code is vulnerable to SQL injection; I would strongly advise sanitising the inputs before just throwing them into a string you're going to run against your database.
Code:
  selectWord = "and"
end if
  selectWord = "and"
end if
  selectWord = "and"
end if
Send me an invoice.
Tx.
how much damage could someone do with Select anyway?
This is so wrong on so many level :erm:
You may want to consider parametrising your query
In any case take a look at the ffg:
USE the COALESCE operator. I do think that there needs to some additional checking involved though.
Also check this link out on dynamic SQL
Code:
where
id = COALESCE( " & txtID.Text & ", id ) and
name= COALESCE(" & textName.Text & " , name) and
surname = COALESCE(" & txtSurname.Text &" , surname) "
Code:
where
Doesn't the COALESCE database dependent?
Can you use it in Ms Access or some other funny dbms?
I will try it though. Tx
