Bullhead fitting, cable gland
SylverTyger
Hi all
I'd like to know where to find a specific type of cable gland, it is used for a pool light housing. I've checked all hardware stores and nobody stocks them, I've even Google's this and can't find any results.
I've attached a picture of it, the first picture should have a rubber grommet as well for water tightness. The second picture shows the same type of grommet but on the actual pool light. The nut size is 21mm.
Hopefully someone can tell what they're called and where to find them.
Thanks.
Hi @krieg
Thanks for the reply, I will search for water tight gland and see the results. When I put the first picture into Google lens, it came up with bulkhead fitting (not Bullhead fitting like the title ). The issue I have with marine sealer is that I need to use this on the housing, which is underwater. The other option is of course use the one from the light in the housing underwater and then silicone the light, we'll have to see if this is really like hens teeth.
Hi @krieg
ARB sells them.
