Thank just wat i wanted to know ill go and buy bc after lvl 50Yes you can, you will not have access to any of the BC content and will not be able to lvl past 60.
I did the same.
Played till lvl 52 on my main then bought TBC.
Hey Petruz.
I tried looking for you the whole weekend, couldn't find you. I would assume your useing a different username
btw. I fixed your Sim this morning, should be working perfectly now.
