Necuno
Court Jester
- Sep 27, 2005
Has one done this before?
Using this to check my calculations
http://www.latlong.net/lat-long-utm.html
http://www.uwgb.edu/dutchs/UsefulData/ConvertUTMNoOZ.HTM
Here's more information on the the conversion
http://www.uwgb.edu/dutchs/UsefulData/UTMFormulas.HTM
http://www.uwgb.edu/dutchs/FieldMethods/UTMSystem.htm
Most of the c# exmaples I could find are using doubles, but when I look at this one's javascript (http://www.uwgb.edu/dutchs/UsefulData/ConvertUTMNoOZ.HTM) and I go through Declarations() (line 9), at f = 1/DatumFlat[Item];//polar flattening.
It would be 1/298.2572236: (using WSG82, which is Item 0 of DatumFlat)
js: 0.0033528106643315514
double: 0.003352810664331551
decimal: 0.0033528106643315511638122819
calculator: 0.00335281066433155116381228192993
The thing is, the page's value at f (JS) is different from what I have at f (C#) which with a zone of 43, easting of 337183.35, northing of 218617.85 and South of Equator gives me: LON: 1.971278 / LAT: -73.536107 instead of LON: 37.857547 / LAT: -87.540331.
I know that the double thing is about precision and capacity, but js AFAIK is using a float number type? The short so far I could not get an example that actually gives same results as the two websites I use to double check it with....
Here's the rough code, I do a pologise, but it is a literal copy and paste from JS
Declarations:
UTMToDD
:edit
Found something that seems to be working in this thread
http://forum.worldwindcentral.com/s...TM-here-it-is-!!&p=66142&viewfull=1#post66142
Code:
DatumEqRad = [[COLOR="#FF0000"]6378137.0[/COLOR],6378137.0,6378137.0,6378135.0,6378160.0,6378245.0,6378206.4,6378388.0,6378388.0,6378249.1,6378206.4,6377563.4,6377397.2,6377276.3];
DatumFlat = [[COLOR="#FF0000"]298.2572236[/COLOR], 298.2572236, 298.2572215, 298.2597208, 298.2497323, 298.2997381, 294.9786982,296.9993621, 296.9993621, 293.4660167, 294.9786982, 299.3247788, 299.1527052, 300.8021499];
Item = 0;//Default
k0 = 0.9996;//scale on central meridian
a = DatumEqRad[Item];//equatorial radius, meters.
[COLOR="#FF0000"] f = 1/DatumFlat[Item];//polar flattening.[/COLOR]
b = a*(1-f);//polar axis.
e = Math.sqrt(1 - b*b/a*a);//eccentricity
Declarations:
Code:
int item = 0;//WSG84
double k0 = 0.9996;//scale on central meridian
double a = DatumEqRad[item];//equatorial radius, meters.
double f = 1 / DatumFlat[item];//polar flattening.
double b = a * (1 - f);//polar axis.
double e = Math.Sqrt(1 - b * b / a * a);//eccentricity
double drad = Math.PI / 180;//Convert degrees to radians)
double latd = 0;//latitude in degrees
double phi = 0;//latitude (north +, south -), but uses phi in reference
double e0 = e / Math.Sqrt(1 - e * e);//e prime in reference
double N = a / Math.Sqrt(1 - Math.Pow(e * Math.Sin(phi), 2));
double T = Math.Pow(Math.Tan(phi), 2);
double C = Math.Pow(e * Math.Cos(phi), 2);
double lng = 0;//Longitude (e = +, w = -) - can't use long - reserved word
double lng0 = 0;//longitude of central meridian
double lngd = 0;//longitude in degrees
double M = 0;//M requires calculation
double x = 0;//x coordinate
double y = 0;//y coordinate
double k = 1;//local scale
double utmz = 30;//utm zone
double zcm = 0;//zone central meridian
string DigraphLetrsE = "ABCDEFGHJKLMNPQRSTUVWXYZ";
string DigraphLetrsN = "ABCDEFGHJKLMNPQRSTUV";
//document.getElementById("EqRadBox").value = a;
//document.getElementById("PolRadBox").value = b;
//document.getElementById("FlatBox").value = f;
//ocument.getElementById("RecipBox").value = 1 / f;
bool OOZok = false;
UTMToDD
Code:
//Convert UTM Coordinates to Geographic
e = Math.Sqrt(1 - (b / a) * (b / a));//eccentricity
e0 = e / Math.Sqrt(1 - e * e);//Called e prime in reference
double esq = (1 - (b / a) * (b / a));//e squared for use in expansions
double e0sq = e * e / (1 - e * e);// e0 squared - always even powers
x = double.Parse(txtEasting.Text.Trim());// parseFloat(document.getElementById("UTMeBox1").value);
//if (x<160000 || x>840000){alert("Outside permissible range of easting values \n Results may be unreliable \n Use with caution");}
y = double.Parse(txtNorthing.Text.Trim()); //parseFloat(document.getElementById("UTMnBox1").value);
//alert(y)
//if (y<0){alert("Negative values not allowed \n Results may be unreliable \n Use with caution");}
//if (y>10000000){alert("Northing may not exceed 10,000,000 \n Results may be unreliable \n Use with caution");}
utmz = int.Parse(txtZone.Text.Trim());// (t parseFloat(document.getElementById("UTMzBox1").value);
zcm = 3 + 6 * (utmz - 1) - 180;//Central meridian of zone
double e1 = (1 - Math.Sqrt(1 - e * e)) / (1 + Math.Sqrt(1 - e * e));//Called e1 in USGS PP 1395 also
double M0 = 0;//In case origin other than zero lat - not needed for standard UTM
M = M0 + y / k0;//Arc length along standard meridian.
if (chkSouth.Checked) { M = M0 + (y - 10000000) / k; }
//if (document.getElementById("SHemBox").checked === true){M=M0+(y-10000000)/k;}
double mu = M / (a * (1 - esq * (1 / 4 + esq * (3 / 64 + 5 * esq / 256))));
double phi1 = mu + e1 * (3 / 2 - 27 * e1 * e1 / 32) * Math.Sin(2 * mu) + e1 * e1 * (21 / 16 - 55 * e1 * e1 / 32) * Math.Sin(4 * mu);//Footprint Latitude
phi1 = phi1 + e1 * e1 * e1 * (Math.Sin(6 * mu) * 151 / 96 + e1 * Math.Sin(8 * mu) * 1097 / 512);
double C1 = e0sq * Math.Pow(Math.Cos(phi1), 2);
double T1 = Math.Pow(Math.Tan(phi1), 2);
double N1 = a / Math.Sqrt(1 - Math.Pow(e * Math.Sin(phi1), 2));
double R1 = N1 * (1 - e * e) / (1 - Math.Pow(e * Math.Sin(phi1), 2));
double D = (x - 500000) / (N1 * k0);
phi = (D * D) * (1 / 2 - D * D * (5 + 3 * T1 + 10 * C1 - 4 * C1 * C1 - 9 * e0sq) / 24);
phi = phi + Math.Pow(D, 6) * (61 + 90 * T1 + 298 * C1 + 45 * T1 * T1 - 252 * e0sq - 3 * C1 * C1) / 720;
phi = phi1 - (N1 * Math.Tan(phi1) / R1) * phi;
//Output Latitude
lblLatitude.Text = (Math.Floor(1000000 * phi / drad) / 1000000).ToString();
// document.getElementById("DDLatBox0").value = Math.Floor(1000000*phi/drad)/1000000;
//Longitude
lng = D * (1 + D * D * ((-1 - 2 * T1 - C1) / 6 + D * D * (5 - 2 * C1 + 28 * T1 - 3 * C1 * C1 + 8 * e0sq + 24 * T1 * T1) / 120)) / Math.Cos(phi1);
lngd = zcm + lng / drad;
//Output Longitude
lbllongitude.Text = (Math.Floor(1000000 * lngd) / 1000000).ToString();
// document.getElementById("DDLonBox0").value = Math.Floor(1000000*lngd)/1000000;
:edit
