Cable Management
I normally use spiral cable management systems, esp for 30cm would be waaaay easier to problem solve than a sleeve.
In my search for where to get em locally google spit out : https://mybroadband.co.za/vb/showthread.php/418736-Cable-quot-wraps-quot
Yea - that was a wall back. It's in the lounge, and I've just got new (well, old pallets) furntiure and want to try make it look a little better than it did.
You're looking for braided cable sleeving, example http://za.rs-online.com/web/c/cables-wires/cable-accessories-ties-tools/cable-sleeves/
https://tinyurl.com/yaljbldw
You can use heatshrink on the ends of the sleeving.
Thanks !
