I upgraded my ADSL line to 4mbps earlier this month, according to telkom my area can support 10mbps but I'm only syncing at 4mbps.
I have tried calling them but I end up waiting 30min + in their queue so I just hang up, can't be arsed to wait that long.
So I came here in the hopes that someone could answer my question.
Downstream | Upstream
SNR Margin (dB): 13.4 | 14.0
Attenuation (dB): 37.0 | 20.5
Output Power (dBm): 12.0 | 9.4
Attainable Rate (Kbps): 9120 | 812
Rate (Kbps): 4096 | 512
as you can see my Attainable Rate is 9120kbps down so does this mean my line can sync at that speed? and if it does why isn't it syncing at that speed?
From what I could gather from telkom a few months ago was that I am quite close to my exchange to it should not be the length of the cable getting in the way.
