Easydoc
Hi, can I use my toptv equipment ( dish, Lnb ) to pick up dstv on a dstv decoder? Maybe just have to move the dish a bit?
Quite a bit I would say. Depending on where in Johannesburg you are, you would have to move it about 106.8 degrees (true) in an easterly direction, about 14 degrees down and turn your LNB about 90 degrees clockwise.You have to move the dish a bit.
