Nope. Only a new battery will solve that
Try and calibrate it first? also hold down alt/option and click the battery icon on the menubar it will state the condition of your battery.
Condition: Normal
Calibrating involves running it completely down then recharging it fully? I have done that before, maybe I should do t again. I remember reading that the batteries do not need to be calibrated.
Condition: Normal
My Macbook Air battery life has never lived up to the advertised figures. Would reinstalling OSX and starting from scratch possibly improve it?
You do realise that the "advertised" figures of 7 hours aren't exactly for Normal usage but involve running low brightness etc.
If you are going to pump the brightness all the way and then watch 1080p movies while doing so the odds of you getting 4 hours is probably about right.
What figures do you currently get with what kind of usage? It should be pretty easy to get 4 hours on average if you don't go out of your way to change the automatic settings.
It might be that your expectation is skewed and that a new battery will give you exactly the same results.
