Cant change volume on PVR, help please
Grimspoon
Skyrim
I have 2 tvs, both using remote blasters from the PVR...On the one TV I can change the volume with my DSTV remote and the other not...Very strange..The one that doesnt work, I have even tried changing the volume by pointing at the PVR itself and no luck. Even if I mute nothing happens...Any advice? Thanks
How are the TVs connected to the PVR?
Check that the audio cable is connected to the "Variable audio" outputs on the PVR.
