Cant view TV guide on multichoice DSTV
syntax
jozi
As per the title, anyone else having this?
Usually if i press info, i can scroll down about a day ahead. Now i just get current and next programme.
My online tv guide does the same thing?
The PVR also decided to no longer record. It had things schduled, but just didnt bother.
I did a full reboot, the recording seems ok, but i still have the TV guide issue. Any ideas?
i was having the same prob and rebooting didn't help. I eventually took out the power plug at the back of the decoder, waited a minute or so and replugged. problem solved. hope this works for you as well. btw mine is the 3 channel hd decoder.
