Rouxenator
Dank meme lord
So its got a year to go until its as good as the dud Sabat you had?
Cost a whole lot less than the SABAT so I'd say its better already
My Astra also came with a Willard that was a size smaller that the car could take. Currently I have the biggest possible size battery fitted, cause it was so cheap![]()
SABAT is crap ... dies within 6 months and the replacement didn't even make it to six months!
Varta / Exide / Raylite <---best batteries (Varta's is fitted in mercedes)
Also look for a 652. That's the biggest battery you can fit in the golf with the most power. (20ah more 200CCA more)
Price is about R860-R950. Got one for my city golf's earlier this year. (Think I actually bought a Willard. Was in a hurry and HAD to replace it.)
652 CAR BATTERY
Dimensions (mm) 277 x 175 x 175 Label Specs AH 65 CCA 530 RC 105
R1055 inc VAT each
http://www.tyretraders.co.za/index.php?page_name=list&type=battery&battery_type_id=1
628/9 CAR BATTERY
Dimensions (mm) 242 x 175 x 175 Label Specs AH 45 CCA 350 RC 65
R750 inc VAT each
AH = Amp hour (How much power the battery can store)
CCA = Cold Cranking Amps (How much power the batter can provide to start a cold car)
Yeah, was planning to put a 674 battery into the golf, but will need to more the radiator about 2-3cm to make space for it.
652 is the perfect fit in a golf.
674 wouldn't fit cos its too high, besides being too big. Why would you need a truck battery in your car anyway :wtf:
Strangely enough, I think it will actually fit. was just a tad bit too long, and I wasn't feeling like moving the radiator cowling.
The 105Ah deep cycle battery was way too high.
Need a big battery for the planned sound system. Wanna try get to 155db :twisted:![]()
