car battery test
GreGorGy
BULLSFAN
Benoniebfkweesnie
Can I test the integrity of my car battery using my multi meter and if so how? Damn Honda didn't start this morning
take it to a battery centre, they test for free if i recall
otherwise i think you can test with a multi-meter, it should show you 12V while off or higher while car is on
It will only tell you how much power you have at that moment, there are a lot of factors when it comes to car batteries (faulty alternators/internal issues) it's better to take it to a battery centre.
Ja - I was worried about that. Problem is, being automatic, I don't want to risk getting stuck and unable to push. I'll just go straight from jump start to battery centre then.
If it's an older car you might want to think about investing in one of those portable jump-start/charger kits you get at Midas etc.
or just a new battery, from the sounds of it it is most definately the battery, whether it is caused by old age or the alternator etc is another question though.
Well that's why I recommended the portable jumpstart kit just in case it happens in the future.
Couple of months ago came out of a 10min visit to a client, turn the key - nothing, not even a starter solenoid click, although radio & hazards still worked. Fortunately there was a Supa Quik just up the road they came & tested, pronounced the battery dead and replaced it.
Never had a battery die like that on me without warning in 30 years of motoring but the Supa Quik guys say it's common with new generation batteries/electrical systems.
Yeah I recently read about the reduced levels of quality in the recycling used in batteries, I'll try find the article.
Couple of months ago came out of a 10min visit to a client, turn the key - nothing, not even a starter solenoid click, although radio & hazards still worked. Fortunately there was a Supa Quik just up the road they came & tested, pronounced the battery dead and replaced it......
Same thing happened to me at a petrol station. In my case it was the brushes in the starter. Replaced them for R55 and the A3 is starting better than ever.
All battery places will test the battery for free.
In a new battery, look at Excide / Raylight or Varta makes.
Almost forgot about this. Very rude of me. So, belated thanks to everyone. When I got to testing my battery at home, my multimedia - in a turn of irony - revealed its own battery to be flat. So, I got it test and that long dangly tester thing said "WEAK" when plugged and "BAD" when loaded. New battery required - and thanks, I got the Exide.
