sssutututu
- Sep 8, 2017
Is there a reason why generators are so extremely inefficient vs a car engine?
We ran a rebuilt P5 VPS F-P5 Skyactiv 1.5 Petrol engine at idle for a 25 hour stability test. It only consumed 11 liters @ 7.4KW on the bench. If you ran this for 100 hours connected to an inverting unit for 5-7KW you would use 36.3 Liters of 95o and have enough power for a lot of stuff at home?
What made me question this is that my generator at home uses ~10 liters for 2-3KW per 7 hours. It would consume 140 liters per 100 hours.
This used and repaired car engine is 10 times cheaper than a diesel generator that can match its efficiency.
So what gives in the generator R&D, Why is it so overwhelmingly bad? Is it made inefficient on purpose?
