Car has low power when pulling away, then comes right
Elax
Pretoria
Hi,
My '99 Opel Astra, with about 278,000 km's on the clock sometimes feels "rough" when pulling away, or loses power to about 75% when accelerating, almost like it's missing, but then all of a sudden it will come right. Would this just be dirty spark plugs or injectors, and is there an easy fix?
My first thoughts are:
Plugs dirty or gaps too big
Fuel Mixture
Vacuum Advance
Some more options to add to your list:
- Faulty idle valve
- Faulty MAF sensor
- Dirt in the fuel pump/line/filter
- Faulty fuel pump (pressure fluctuates)
with that mileage it could be anything. non of us and can tell you the problem, just take it to your local mechanic or dealership and they will diagnose the problem for you.
