^^vampire^^
- Feb 17, 2009
Hi Guys, I have a 2004 Citroen C3 1.4 HDI.
Parked at a shopping centre on Saturday afternoon (had already driven around in the morning and have had no issues prior) and when I got in my car and put the key in the ignition and turned it... nothing.
The ignition lights on the dash don't turn on (oil, turbo etc) and the little display on the dash with the Km's etc doesn't light up. When you open the door because of the system that turns the inside light on etc only then does the little display on the dash turn on. The radio works fine, the inside light on the roof works fine too.
I tested the battery in another car and it works fine and tested another battery in my car and that works fine too. The battery system on the dash flashes though when i open the door but otherwise nothing. The power windows also don't work but they only work then the ignition is on normally.
I've also checked all the fuses so my only idea left is that it must be the ignition relay. My attempts to find even one relay in this car has failed so far - does anyone know where i might find the relays specifically for the ignition?
