123Eish
Hi guys
I recently decided to upgrade my sound setup in my car but I'm having a problem.
This is what is installed a star sound monoblock amp it's rated to put out 1300rms at 1ohm to the subs, the subs are two pioneer 400rms dvc subs each, they are wired at 1ohm in parallel to the amp.
Then I have another amp 4ch star sound for the other normal 6.5inch speakers and 6x9 no problem here.
I have a 4 gauge wire running from the battery to the boot, in the engine bay iv got a 80amp fuse, it's one of those double fuses that you get at the fleamarket so, I basically fed the battery cable into the input and then bridged the second out put with the first output, I'm no auto electrician but wouldn't this give me 160amps on the fuse in total, 80 per fuse.
Then the 4 gauge cable runs to the back of the car, into another double fuse same as what's in the engine bay, one output goes to the monoblock and the other to the 4ch. Then out into the amps with 4gauge wire.
Here's the problem the fuse in the engine bay remains cold it doesn't get hot besides the engine heat making it warm. But the one in the boot specifically the output of the fuse which goes to the monoblock gets really hot, you can't touch it. But the output going to the 4ch of the same fuse is cold.
Problem one above bow here's problem two:
The amp plays really nice hard bass perfect for me, but if I increase the volume past say 40 on the deck the amp shuts off, the monoblock amp, the other stays on. The amp does not go into protection mode or show any warning light it just dies, then if I put the deck of for say five minutes it starts working again. I presume this is a power problem and the amp is shutting down because of maybe a voltage drop. I say voltage drop, because my lights in the car dim, and so does the instruments on the steering wheel as well.
What could be done to fix this problem, my battery is only about a year old, should I do a big three upgrade, capacitor bigger battery. I'm also looking for a cost effective solution.
If any of the components I'm using is incorrect, please could you specify the correct components and where I should purchase them, and if I need a capacitor, what type and how much far ads should it be
Thanks in advance guys
