ryan_black13
- Oct 12, 2010
I have a BMW 316i '95 model. Would it be a mission to install a sound system? Ie. Mp3 player etc..
Well, if I am correct, it is the dolphin shape...? Will look for pic quick.
Edit:
http://i275.photobucket.com/albums/jj302/BrianX91/P1140785.jpg
Found this image on google, but having problems viewing it...
For the costs, you will have to drive from shop to shop and ask, don't just go to the first shop and do it there, some will be more expensive than others, maybe ask them how much it will be fitting the radio...?
It's not that big of a mission, but it ain't no quick job either. Luckily the battery is in the boot, so if you add some amps, that helps a lot. I think your biggest problem will be getting the bass into the cabin, those boots are pretty good sealed.
Cruising altitude, you mean...Not bad- that speed at those revs.
How's the road noise at 'cruising speed'?
I am rather pi$$ed off at the installers because I got that alternator whine....
they charged me R1k for the install alone....(they have since closed)...
R1k for installation alone is a decent price?
I must admit that I was so impatient to have my sound installed...it took me a year to buy the hardware piece by piece and when the woofer was bought, I just had to have it installed....
impatience costs you....
