spiderz
Any suggestion on where to hire a car trailer? and what it costs +-?
Need to move a Land Rover from JHB to PTA.
That is a seriously heavy load. You will need a braked trailer.
http://www.trailarent.co.za/trailercar.htm
These guy make them. Check if they have any clients that rent them out.
http://www.cartrailers.co.za/
I have personally used Trailer rent in PTA-West. Cheap was around R 140 (or was it R 240 ?) a day for a double axle trailer.
Edit: Sorry it was West Trailers not trailer rent
Dan the trailer man. I have seen many of their trailers around. In various shapes and sizes..
You'll find the number on the net.
Make sure you have a code EB license btw. Though, car + trailer + landrover probably exceeds 3500kg - so you probably need an EC license
Land Rover Weights 3459lbs (1570kg)
http://www.cleveland.co.jp/specs/old.html
What will you be pulling it with?
Add 500kg or so for the car trailer and you'll be skating a fine line...
/has license to tow
but many I know do not.
And the irony is that I hate towing trailers/caravans
I refuse to tow another car unless that driver knows how to handle a towed car. Must brake/slow for both!
Range Rover 4.6 V8
Should be rated to tow more than that!
The further irony is that I DON'T have an EB license, due to my SA license expiring, yet I can alley dock 2 ton keelboats quite happily.
Bwhahahabahaha
sorry
But it is funny... You may not but you enjoy. I may, do, and don't enjoy.
