I have a 1989 Toyota Corolla 1600 4A-F
It suddenly has stopped idling when hot. It will idle just after starting for a few minutes and thereafter will die whenever it should idle. I can restart immediately and it runs fine. If i carefully add throttle after restarting it may then idle for a bit but hunts between 800 to 1500 rpm. It seems that there is no fuel
I have tried replacing the fuel and air filters, cleaning the carb with carb cleaner, checked the sight glass to see that the float level is fine, but cannot get to the root of the problem. It's got a sophisticated vacuum system (vacuum diagram)
Any suggestions?
I think I may have to take it in to a carb specialist - does anyone have any recommendations for one in Joburg?
Any suggestions?
