Cause for concern?
janplank
JHB
This url shows the SMART info from my seagate 1TB hdd. I am not sure what it all mean. The SMART info on my other drive shows everything 100%. Can someone please tell me if this is bad news or not. I don't want to loose my data AGAIN!
Yea back up dude, unless you have 3-5k for possible recovery. You should never worry about losing your info.
Should I replace the hdd? it has got about 4 months running hours on it...:mad: It is not even that much. Since my last experience, I have a backup but just the import stuff.
What software did you use to produce the smart report?
Is it still under warranty?
take it back and claim a new one.
It should be, normally it is 3 years warranty? Would I have a leg to stand on if the drive has not physically failed yet?
Now where did I put that receipt???? :erm:
I replaced 2 drives with bad sectors.
if it's seagate, try to take it to ractron (even without invoice)
